420 steering
Garrett Wirth
06-12-2001 08:00:22
HI,
I HAVE A 1956 420T AND WHEN IT IS IN 4TH GEAR HI IDEAL THE FRONT TIRES START TO SHAKE AND WOBBLE.I TRIED TIGHTING THE STEERING BUT THAT DID NOT WORK. ANY BODY KNOW WHAT IS WRONG? THANKS
L.C.
06-13-2001 20:53:35
 Re: 420 steering in reply to Garrett Wirth, 06-12-2001 08:00:22
A couple of thoughts: if it's the tricycle front end, it could be worn wheel bearings and/or spindles or a rim or tire out of round. A wide front end could have play in the tie rod ends.
Try raising the front end so the wheels can spin freely. Make sure the tractor is securely supported, then check each wheel for wobble. Stand at the front of the tractor and spin each wheel and watch the tire to see if it spins straight.
Hope this helps.
