AR unstyled clutch pad access?
Donny
06-11-2001 21:22:59
How does the cast part that holds the brakepad against the pulley come off so a new pad could be put on.Thankyou.
Bob Collins
06-12-2001 05:18:17
 Re: AR unstyled clutch pad access? in reply to Donny, 06-11-2001 21:22:59
Donny, You can take the whole assembly off by disconnecting the clutch rod that goes to the hand clutch lever and removing the four bolts that hold the clutch fork shaft bearing to the tractor. Pay attention to where the brass collar fits in the clutch operating sleeve inside the housing so that you can put it back together right. A parts or service manual is helpful. Thanks for wanting to put on a real rivet on pad and not one of those quick fix bend the tab over type linings. Good luck. Bob
