John Deere 730 that lost its front end.
Paul
06-11-2001 18:59:02
I was out mowing hay here in PA, and I came around the feild for the 5th time and went to turn and the front end went out from under the tractor. But the good news is 3 hours later and 4 new bolts we were back mowing again. It didn't break and thing except for the bolts. 2 of them unthreaded and the other 2 broke off is this common for a 730? I just bought it, I love it but and worry about running it now for fear the the front tires will fall off. It is a narrow front with rollomatic. Thanks for any help. The bolts were harden and had lock washers. The feild was level and had not holes. It broke where it bolts on to the bottom of the tractors were there are 4 bolts.
David B.
06-12-2001 10:13:34
 Re: John Deere 730 that lost its front end. in reply to Paul, 06-11-2001 18:59:02
When replacing the bolts on the rollamatic. The bolts should be 3/4" X 2.5" high strength with lock washers under the heads. Do not use longer bolts. There is a seal retainer above the vertical steering shaft. If too long of bolts are used they bend retainer causing the seal to fail.
don
06-13-2001 15:17:42
 Re: Re: John Deere 730 that lost its front end. in reply to David B., 06-12-2001 10:13:34
Dave is correct except for the lock washers. they will cause the bolts to work loose. use grade 5 bolts and torque to 300 ft lbs and you should be ok , assumeing the holes and threads are sound.
Greg H.
06-12-2001 08:33:40
Paul,
Bolts do work loose. On my 4020 with rollomatic I check them every year, usually when I change my oil, and clean out my dust bowl below my air cleaner. Brother-in-law nearly lost the rollomatic out from under the 3020 this week while going over the road at about 16 miles an hour. He said he looked down, and saw the front end wobbling, and when he stopped the tractor only two bolts were still attached to the pedistal, and they were loose. Back tracking he found one of the other ones, and had to replace the fourth. Needless to say check those bolts everynow and again, just like you would any other part of the tractor. Greg H. PS somethine else that will give you a thrill, is snapping the bottom rollomatic part of the front end off the pedistal, while the tractor is moving. It was such a bad feeling plowing your front end into the ground, and watching my front wheels roll on down over the hill. I gotta tell you it makes me want to go use the bathroom just remembering it. Anyhow, keep your bolts tight, avoid ditches at high speed and ground hog holes, and everything will be fine. Later Greg H.
Haybaler
06-12-2001 06:30:40
Mine has come loose twice (working tractor). Just made it a part of the service routine to check it now in the spring, midsummer and fall and haven't had a bit of trouble. Just have to keep an eye on it.
Dan from Washington
06-11-2001 21:15:18
Don't think that is a normal problem, especially on mostly smooth ground. I would think the other bolts must have been loose or possibly a couple missing for it to break like that. After you put the new ones in tighten them after running a short distance, then again later. I'm not sure of the size bolts in the front but they should be torqued accordingly.
Duben
06-11-2001 21:13:41
The same thing almost happened to me on the 730 I used to have which was a square tube wide front. Was mowing and I couldn't steer it - wanted to keep going in circles but would be ok after awhile. Had a friend look at it and only one bolt was left! Probably just something to check on occasion - could be someone changed the front and didn't tighten the bolts all that good.
