John deere model 60 ser#6028872
ben parson
06-11-2001 14:15:08
I,am restoring a model 60.It has a 6 speed transmission.But 1st gear is too fast for loading. Dose this tractor have low range.I,am unable to locate a shifter on tractor for high &low. It has the geae shift on the left of steering wheel.An a small shifter on the right.Hand clutch on the right of steering wheel.PTO shifter in the floorboard. thats all.
1st gear
06-13-2001 08:54:38
 Re: john deere model 60 ser#6028872 in reply to ben parson, 06-11-2001 14:15:08
1st gear is too fast for loading what? Get yourself the manuals (operator's and parts) then you will have all the answers!
Charles
06-11-2001 15:29:07
The 60 has no Hi-Low range. The 6 gears you see are all. The small shifter on the right must be the throttle. Looks like a small hand clutch mounted on right side of dash.
Charles
Ben Parson
06-12-2001 10:58:27
 Re: Re: john deere model 60 ser#6028872 in reply to Charles, 06-11-2001 15:29:07
The small shifter on the right goes down into the transmission.It shifts a gear in an out on the outside of the transmission. We have the side palte an top palte of transmission off.This shifter shifts a gear that runs off the gear on the end of the crankshaft.
Jason
06-12-2001 15:45:36
 Re: Re: Re: john deere model 60 ser#6028872 in reply to Ben Parson, 06-12-2001 10:58:27
that gear and shifter drives the engine driven or "live" pto when optioned for it, if this id the case there would be a lever on the left side of the battery box/seat
