56th Gear Stuck on Shaft
Dan King
06-10-2001 00:27:09
I'm trying to remove the 5th & 6th Gear from the sliding gear shaft on a late model B. The JD shop manual shows two tapped holes in the gear into which to bolts are inserted and tightened to push the gear from the shaft. My gear does not have tapped holes. I'm using a gear puller, long handled 1/2 drive rachet, cheater bar and 330Lbs. of butt to tighten the puller. I can't budge it! The Sliding shaft is keyed and the gear appears to be keyed also. Could this be a wedge? Help!!
Bayou Dave
06-10-2001 18:31:15
 Re: 56th Gear Stuck on Shaft in reply to Dan King, 06-10-2001 00:27:09
Like Chuck said, plenty of heat on the gear.
Chuck
06-10-2001 10:52:29
have pulled many of them some come off okay, other have had to apply heat to the gear...don't heat the shaft....
