Fuel Valve and Water Injection
Mike Hayes
11-23-2003 15:11:44
I'm working on a 1941 "D" model and have a couple of questions. The tractor has a fuel shut off lever that sticks through the dash and has three positions marked "OFF", "G", and "F". I have been told that because fuel oil or kerosene was less expensive than gas the tractors were started on gas in the "G" position and then switched to run on kerosene in the "F" position. Is this correct? The tractor also seems to have a water injection mechanism that routes cooling system water from the water jacket around the cylinder into the carburetor. How does this work and how was it adjusted? Any information on the operation and function of these features would be appreciated. Also the tractor has no starter, generator, shutters, or lights. Was this an option for this year or have they been removed? Thanks.
John T
11-23-2003 16:48:34
 Re: Fuel Valve and Water Injection in reply to Mike Hayes, 11-23-2003 15:11:44
Mike youre thinking about right as clooney pointed out. Those valves are referred to as "3 way valves", to control whether FUEL or GAS or OFF was desired. They used gasoline in the smaller often red capped tank to start, and then after a warm up to around 180 to 190 degrees or so, they switched over to Distillate or Drip Fuel similar to todays Kerosene as it was cheaper then. HOWEVER, it is low octane and ignites so easily it caused pre igniton spark knocking.
THEREFORE, your second question, water was injected to prevent that pre ignition spark knocking, and the control valve you mentioned was opend just enough to accomplish that.
In winter, they had to drain the water out each night also.
Good luck n God Bless ya Mike
John T
Clooney
11-23-2003 16:00:23
Mike, you ask..."The tractor has a fuel shut off lever that sticks through the dash and has three positions marked "OFF", "G", and "F". I have been told that because fuel oil or kerosene was less expensive than gas the tractors were started on gas in the "G" position and then switched to run on kerosene in the "F" position. Is this correct?".....Yes that is correct. The small rear tank held gasoline for starting & warm-up, then after the engine got up to around 190� the gasoline was turned off & the tractor fuel [close to kerosene] was turned on... The engine temperature must be kept at or above 190� to properly burn that tractor fuel... Unless you are working the tractor just use gasoline in both tanks.. You can work the tractor on gasoline if you want also..
~You also ask about that water valve?...That was used to remove spark knock & detonation while working the tractor on tractor fuel... It metered in water from the engine cooling system to cool the combustion process when using tractor fuel... You just open it until the knocking stops.. The reason that water valve was used is because kerosene, & tractor fuel has a very low octane rating. Without adding water to the combustion process those big piston D's would knock like crazy under sustained load..
~DON'T open that valve if you have antifreeze in the radiator as that is very hard on the engine... If you are using gasoline you don't need any water either... Unless you are working that tractor hard on tractor fuel or kerosene -- DON'T OPEN THAT WATER VALVE.....
~I think electric starting came out as an option on the D in 39 or 40.. Most didn't have it though..
[email protected]
