Jd b pops out of gear
doug murray
06-09-2001 06:06:24
my 48 jd bw pops out of 5th gear when going down steep grade. the shift lever doesn't move so something going on inside. i have to move the lever over to the right quadrant to get the tractor to move again. only seems to do it in 5th. any ideas would be greatly appreciated. thanks, doug
Jack
06-10-2001 19:48:41
 Re: jd b pops out of gear in reply to doug murray, 06-09-2001 06:06:24
My 50 did the same thing, but it had gotten so bad that it would do this in 3rd and 6th as well, even while under load. I cured it by lengthing the left end of the lowermost slot in the shift gate, the one you use to shift from the right quadrant to the left, about a half inch with a die grinder. This allowed the shift lever to move further and fully engage the dog clutches between the sliding shaft drive gear and the tranmission drive gear.
It hasn't jumped out of gear since.
