Dan, you could have any number of problems on that D.. From a lack of fuel flow, to a poor spark, to bad spark plugs, to a plugged air cleaner [or water in the lower cup], to a points gap problem in the mag, to internal carb problems.... ~Start with a brand new set of spark plugs.. [fouled plugs could easily cause your problem].. ~You really should do a fuel flow test to see if you have a fuel flow restriction [common problem].. To do that, slide a pan or piece of plastic under the carb [I know there isn't much room in there], then open the carb drain & let the fuel flow out for a good 30 seconds,, you need to see a pencil sized stream of fuel flowing out for at least 30 seconds, if you don't have that fuel flow, pull the fuel line loose & check the flow there.. If you don't have a good fuel flow make sure the fuel valves are set correctly & that the fuel strainer screen in the carb & fuel shut-off isn't plugged. ~If the fuel flow is good to the carb & you have installed new spark plugs you could have a plugged load nozzle in the carb, to check that, pull the carb off the tractor, then pull the float bowl off the tractor.. There is a brass load nozzle up in the main well [where the bowl nut screws on].. To get that out just run a tap into the bottom of that nozzle about 3/8", then install a piece of all-thread rod with a stack of washers & nut on it.. When the nut is tightened the load nozzle should pull out [DO NOT pry on the top of the load nozzle to get it out]... ~You could also have a weak ignition system [I presume you have a Wico mag?].. A weak ignition system could run ok under low loads but act up as the combustion pressures come up under a load... To test for that, take an old [known good] spark plug & open the plug gap to 3/16", then install that large gap plug in one plug wire at a time & lay it on the engine block ... If your mag is functioning & sparking correctly you should see a bluish spark jump that 3/16" plug gap on every other snap of the mag.. If it's intermittent, yellow, or weak looking you have mag or plug wire problems.. [if you have a poor looking spark post back or E-Mail] ~By what you have said it sure sounds like you either have a fuel starvation problem, fouled spark plugs, or a weak ignition,, but it could be almost anything else from a leaking valve, to carb load needle adjustment, to ?.. ~On those hot spark plugs?.. that is normal on a working tractor.. A lean condition in the combustion process can make them even hotter.. ~I'm sorry I can't be more specific on your problem.. do some of the above & maybe we can isolate the problem to a system like either fuel or spark.. ~One more question?... Does pulling the choke out while the problem is happening make any difference? If so let me know? [email protected]
