Bill, if the cap fits the distributor, it may work IF its internal terminal pick ups are in line with where the rotor is pointing when the points open and the terminal to the plug thats supposed to fire (cylinder 1 or 2) then is electrically attached to that terminal. Remember, on the vertical distributors that run at 1/2 crank RPM, the crank has to advance 180 after firing the left cylinder before the right, but thats just 90 degrees of distributor shaft rotation. HOWEVER if horiziontal and ran at governor RPM, which is the same as crank RPM, 180 of crank rotation (between 1 and 2 firings) also must equal 180 of distributor shaft rotation. Regardless, the rotor tip has to be in line with an inner cap terminal when the points open and in line with the correct terminal connected to the plug thats supposed to fire then. Of course, the right cap and part number for the right distributor answers your question, but just from considering distributor RPM and looking in the cap to see the degrees between its terminals (90 or 180) can help you understand whats happening. Good Luck n God Bless ya Bill John T
