restoring a 1935 JD A
arthur H.
11-23-2003 11:23:43
helping restore a 1935A need to know where the blank space in the oil ring grove goes up or down also what is the torque on the cilinder head bolts
and what the valve settings are? are there any things to be careful not to forget on asembly
was mecanic for many years but never had a JD in the shop lot of gray and red but no green.
i look at this forum almost daily lot of good people helping others with there problems keep up the good work. Art H.
Clooney
11-23-2003 14:49:41
 Re: restoring a 1935 JD A in reply to arthur H., 11-23-2003 11:23:43
Arther, the oil ring gap [or gaps] face up. You want to make it as hard as possible for oil to get by the bottom of those oil rings. If you have the multi-piece oil rings put the gaps up but stagger the gaps...
~The valve settings are .020" hot [that's working hot, not just idle for a while hot].. I usually just set them to .022" cold at assembly then use the tractor for a short period then reset the valves when the cylinder head is re-torqued..
~Now on your head nut torque.. I'm not sure there are any on the 35 A,, that's a little early for Deere to have given torque values.. Make sure you install those lead washers between the cyl head nuts & cylinder head.. The later A's used a torque of 125' lbs [start at the center & work out]....
[email protected]
arthur H.
11-23-2003 15:06:23
 Re: Re: restoring a 1935 JD A in reply to Clooney , 11-23-2003 14:49:41
clooney about the oil rings. the pistons have holes in the grove for the oil ring but not all the way around the space wear there are no holes shuld that be up or down .art
