3020 - Gas with bad crank
mark garvin
11-23-2003 07:29:02
I have the opportunity to buy a 3020-gas from a local farmer. He put new pistons and rings in it and did not replace the bolts in the rods. The dealer is telling him that it has broke a rod, and may need a crank. It has brnd new rear tires, 1 remote. But I need to know what is this tractor worth. I plan to restore it and park it next to my 2 - 2010's. Thanks
Jim
11-26-2003 06:10:45
 Re: 3020 - Gas with bad crank in reply to mark garvin, 11-23-2003 07:29:02
i would try to buy it for $1500 and rebuild it myself. I made the mistake of buying a 3010 diesel that was up and running, then it broke the cranks in about 100 hours. Now I am spending about $1800 in getting it back in shape.
At least I know what kind of shape it is in now.
Jim
Brokenwrench
11-23-2003 09:12:06
I wouldn't put more than $1500-1800 in it. You can buy them up and running for around $4000. You don't know what you will have to put in the engine,you might get lucky and just need a crank,rod,bearings,and some gaskets.Or it may take a whole short block depending on what damage the rod did when it broke.Plus factor in whatever else the tractor needs to get it to your idea of restored.
mark garvin
11-23-2003 17:47:29
 Re: Re: 3020 - Gas with bad crank in reply to Brokenwrench, 11-23-2003 09:12:06
What should I pay for this tractor as it sits? and not knowing what has to be done to it to get it up and running.
