Handsome Jim
Ernie
11-23-2003 06:05:48
I called JD yesterday about the frame brackets and for the clamps and brackets they are around $250.00. I had the clamps that was for the 1520 with the telescoping arms so I took my angle grinder and made a wider slot in them to fit my arms. Drilled new hole and made some new clamps. I mounted it on the tractor and it worked but don't know how long it will last without breaking. I plan on mowing hay with it if I can.
Handsome Jim
11-23-2003 15:47:54
 Re: Handsome Jim in reply to Ernie, 11-23-2003 06:05:48
Hi Ernie, The farmer I bought my #39 from had used it with his 3020. After I got it home and saw that it wouldn't complety hook up, I asked him if it would be a problem using it that way and he thought the only problem might be that the bar might not break back if I'd hit an obstruction. Well, I can tell you that's not the case. I've prbably come up against 10 stumps that were hid in tall grass and it worked every time. I do hook up every thing else per the manual and the bar raises when I raise the 3 pt. I had thought about 'manufacturing' some brackets to make the bolts work but so far it hasn't been that big a deal.HJ
