JD 60 idle rpm
sodbuster
11-22-2003 15:52:13
Does anyone know what rpm a 60 should run? Mine dosent want to idle like other two cylinders. I put the throttle all the way back and it just keeps slowing down till she dies. Is there a way I can find the exact rpm that it idles at?
Ron
11-22-2003 21:59:50
 Re: JD 60 idle rpm in reply to sodbuster, 11-22-2003 15:52:13
The book calls for 600 RPM... I like about 400...
The manual explains how to set the idle speed, adjust the mixtures, then run it on one cylinder ( 300 RPM ) and adjust for the fastest idle, then the same for the other cylinder, the same way.. I kind of think that you have the idle mixtures set too rich, and it slowly "loads up", and dies.. Let us know...!! Ron.
