??? Model 80 Hydraulics
Alan Hughes
10-14-2003 15:34:14
I own a 1956 John Deere 80 with PTO and dual two-way Hydraulics. I would like to use it to Plow and Disc but our equipment is all fitted with one-way cylinders. Power up, Gravity down, Only one hose needed. (Left over from our days farming with an off colored M that only has one-way hydraulics). I know our 730 Diesel has a cap screw that can be reversed to take the hydraulics from one-way to two-way and vice versa. Is there a similar adjustment on my 80 and if so, where is it? I would like to avoid simply running a return line into the drain if I could. Thanks in advance,
Alan Hughes
WI
Brandon
10-14-2003 16:33:22
 Re: ??? Model 80 Hydraulics in reply to Alan Hughes, 10-14-2003 15:34:14
If I remember correctly, 80's with dual hydraulics could only use two way remotes. That is strange, because with single hydraulics, you could switch between single and two way remotes!
Brandon
My Industrial John Deere website
My JD model 80 website
The LaGrange Engine Club
