6 volt battery
Dick C
11-22-2003 08:24:29
I am getting ready to purchase a starting battery for my newly restored JD 1945 B. It is equipped with both starter and generator and has the 3 lamps. Is there anything in particular I should request or avoid in selecting this battery?
Thanks
John
11-23-2003 17:58:44
 Re: 6 volt battery in reply to Dick C, 11-22-2003 08:24:29
I put grease on my battery terminals, trays etc. and never have a problem with battery corrosion again.
Steve - IN
11-22-2003 13:49:22
Dick,
You won't find lot of choices in makers, but will find a lot of choices in brands - there are only a few battery makers in the country, but they slap all kinds of brand names on the same battery.
Basically, you'll probably be buying a battery made by either Exide or Johnson Controls. Exide = GNB, Champion, K-Mart, NAPA, etc.
Johnson Controls = Sears' DieHard, Auto Zone's Duralast, Wal-Mart EverStart, etc.
A BCI Group 1 lead acid is a sure fit, and will be rated at 600 to 625 cold cranking amps. Retail price will be 50 to 70 dollars depending on the tax. For other 6 volt group sizes, check this chart.
Link
You should also consider a sealed battery - brand names Optima or Interstate model AGM-850/6 - made by Johnson Controls. The advantages are: 1. 30 to 35 per cent more cold cranking amperage at ~800cca. 2. No gas leaks, so no corrosion - you don't need to fool with felt pads, protective sprays, nor do you have to watch a new, or newly refinished battery box get corroded in a year or two. 3. Service life generally exceeds a lead acid by 12 to 18 months.
There are two sellers of sealed 6V Optimas on eBay now for 89.95 delivered. It will fit a BCI group 1 box diagonally. A waste of money? No, just proof of the adage - "you get what you pay for".
Garl
11-22-2003 20:25:53
 Re: Re: 6 volt battery in reply to Steve - IN, 11-22-2003 13:49:22
$90.00 for a battery? I dono what kind of a deal you got going there. That thing would half to last 24 yaers to get what you pay for. Just put a exide in my old tractor it cost me $29.00 at the co op. Last exide I had in that old tractor lasted 8 years.
Steve - IN
11-23-2003 04:26:00
 Re: Re: Re: 6 volt battery in reply to Garl, 11-22-2003 20:25:53
third party image
Garl,
Sure, they last 30 years in a perfect world. I don't live in one, but would settle for your world. Here's a graph from ACDelco reporting the results of a survey of 5800 lead acid batteries replaced in shops all around the country. Average life is around 50 months; a tad over 4 years.
The only local place that even stocks lead acid 6V starting batteries around here has a BCI Group 1 Deka/East Penn in their flyer at $57.39 including tax. It's rated at 635CCA.
Congrats if you're getting twice the life at half the price. Until I get in that state of grace, I'll settle for the pricey one that has a quarter more cold starting power, won't corrode the battery box or the connectors, and does live substanially longer than the average lead acid battery.
John T
11-23-2003 07:05:50
 Re: Re: Re: Re: 6 volt battery in reply to Steve - IN, 11-23-2003 04:26:00
Steve, In those colddddd d Hoosier winter days, especially if a 6 volt system, Im like you and want alllll ll the amp hours or cold crank amps I can get, even if it requires the extra bucks for a sealed battery. That coupled with 00 Gauge Cables and a well tuned hot mag or ignition makes alllll l the difference.
Your neighbor, John T
Steve - IN
11-23-2003 17:18:03
 Re: Re: Re: Re: Re: 6 volt battery in reply to John T, 11-23-2003 07:05:50
John T,
Truer words have never been spoken... It's a test of character even to walk out to the barn or shed when it's 0 degrees and the snow is covering the ice that could make you slip and end up on your heinie. Next test is when you punch the starter - a good result is a source of amazement; but that slow grind is one of those things that "try men's souls".
Wes
11-22-2003 11:46:18
I use an 8 volt battery in my 47 A. I like the extra cranking on cold days when I have to plow snow. THe generator has no trouble keeping it charged.
Clooney
11-22-2003 10:18:22
Dick, John's information on using the biggest highest cranking amp 6 volt battery you can is sound advice.
~Problem is there isn't much available at a decent price.. The battery height is a problem & the group 1 is about the best fit... It would be nice to go up to a group 3 or 4 but the height will then allow the battery posts to hit the seat bottom.
~A good group 1,, 6 volt battery [that's the one that's designed for the "B" battery box] will give you about 625 CCA @ 0�F & about 750� CA @ 32�F.. That's plenty to start that "B" if it is in decent shape [sounds like it is] ..
~If your "B" has a magneto, about anything will start it that will turn it over.. With a distributor the battery makes a little more difference as any voltage drop due to battery size, temperature, & cable condition will adversely effect the ign coil's output & that can really effect the cold starting..
~If price is no object & you want to shop around you might find a specialty battery that will up the CCA & still fit but that probably would be a waste of money.
~In my personal 6 volt tractors I just use rather cheap group 1-HP [commercial] 6 volt batteries as age kills them as fast as anything so that allows me to replace them every 3 years or so & still keep the price reasonable..
~ I have an older 6 volt battery chart that shows battery groups, CCA, size & overall dimensions.. If you send me your E-mail; address I will send you a printable chart for those 6 volt batteries...
[email protected]
Jake
11-22-2003 10:01:58
I've been having great success with batteries made by East Penn / Deka sold under various names. They are sold by CARQUEST here in Minnesota and also Mills Fleet Farm under their brand. East Penn assured me they are the exact same battery except for the label stuck on them. The other difference is that the Fleet Farm (6 volt) battery that most of the older small tractors use is half price than the one with the CARQUEST label on it. I get 8-10 years out of quality batteries with proper care and storage.
The WORST batteries I've had are EXIDE (and the various brands they are sold under).
John T
11-22-2003 08:36:36
Dick, my general advice on 6 volt tractor batteries, is to buy the highest rated (amp hours and/or CCA) heaviest duty and biggest frame size battery that will physically fit into the compartment. Some of the heavy duty truck and tractor rated units are designed to better withstand vibration. Then I recommend 00 Gauge starter and ground cables and use both the felt washers under the terminals then spray them with terminal protector. Have all ground and starter and battery connections clean and tight.
Good luck n God Bless
John T
tom
11-22-2003 08:55:17
 Re: Re: 6 volt battery in reply to John T, 11-22-2003 08:36:36
Dick,
I concur with John T. in everything...I have recently over-hauled the entire electrical system [ign. switch, 6v gen, starter, coil, replaced all the wiring, etc] on my 2-popper, and when getting ready to discard some old rubber gloves, I did a double-take while looking at my 6-volt battery before I installed it again.
Good clean cables are a must, but a maintaining a 6 volt battery is a must...in the bottom of your battery try, I have taken some old rubber gloves, cut them up and lined the bottom of the battery tray...they work great to: cushion the battery from constant vibration, provide the same effect as a lock-washer when you tighten the top of the battery hold down frame to the battery. It also helps the battery from slipping around too...
I cut them so you can not see them from any view, only when you remove the battery...
just some food for thought...good luck,
tom
