70 Powertrol
jdman(MO)
11-21-2003 19:26:48
Having problems with my wood splitter. added 4 qts of oil and still nothing out of the check hole. I might add I am using a 6 inch cyl with 36 inches of extension. The splitter is working but even retracted nothing comes out of the check hole. Using closed plug, and metering screw all the way in. Shall I put more oil in? Russ
Clooney
11-22-2003 05:22:13
 Re: 70 Powertrol in reply to jdman(MO), 11-21-2003 19:26:48
Russ, are you using a single pressure hose with no return hose & a spring to return the cylinder?.. If so, retracting the cylinder piston will change the cylinder internal volume..
~If you are using both a pressure & return hose to that cylinder, it will hold about the same volume of oil at any place in it's travel..
~I would guess that cylinder would hold close to 2-1/2 to 3 Gallons of oil..
~If you are using 2 hoses to that cylinder add more oil..
[email protected]
jdman(MO)
11-22-2003 08:44:56
 Re: Re: 70 Powertrol in reply to Clooney , 11-22-2003 05:22:13
Thanks for the info, the cylinder does have pressure and return. I was afraid if I added more oil and the cylinder retracted it would overfill the tractor. The cylinder if off a CAT and will split anything made of wood, but is a little slow. Slow is not necessary bad when splitting wood. We originally made it to split post, but I have cut off about 2 feet so as to reduce the load on the 3 point. Russ
Clooney
11-22-2003 12:18:20
 Re: Re: Re: 70 Powertrol in reply to jdman(MO), 11-22-2003 08:44:56
Russ, with 2 hoses on the cylinder any oil that comes out of one end goes back into the other..Nothing gained/ nothing lost..
