JD 39 Sickle bar mower
Ernie
11-21-2003 17:29:51
Could someone tell me which frame brackets I need to mount this mower on a 1520 JD? The ones listed in the parts book for a 1520 is for telescoping draft links and mine has the regular links not telescoping. Is their another model JD with the same size draft links as mine? Mine are 3 1/4 inches. Thank you
Handsome Jim
11-22-2003 20:52:57
 Re: JD 39 Sickle bar mower in reply to Ernie, 11-21-2003 17:29:51
I use a #39 behind a 1020 with the same style draft arms without using the clamps. I don't advocate that you do this, but I don't have any problems but I don't use it in any difficult conditions, just trimming around the lake. I've be thinking of trying a salvage yard to see if I can get the other syle arms but haven't gotten that far.HJ
Jim Devany
10-04-2004 07:21:28
 Re: Re: JD 39 Sickle bar mower in reply to Handsome Jim, 11-22-2003 20:52:57
Where can I find a manual and parts for the JD 39 bar mower please?
Jim
John
11-22-2003 13:24:51
You are not the first guy to ask the question about draft link thickness as the flat ones seem to vary slightly for the smaller Deere tractors. Particularly when attaching those clamps. I ended up making my own out of 5/8" flat stock and they worked well.
