GENERATOR QUESTION
ERIC
11-21-2003 14:50:40
I WOULD LIKE TO PUT A DELCO-REMY #1101390 ON MY 45 B. WILL IT WORK? JUST WAN'T TO RUN A LIGHT ON THE BACK OF THE TRACTOR IT IS HAND START AND PLAN TO KEEP IT THAT WAY. BOUGHT A GENERATOR AND NEED TO KNOW HOW TO HOOK IT UP. CAN I CHECK TO SEE IF IT WORKS BEFORE PUTTING IT ON THE TRACTOR? SHOULD I TAKE IT TO A ELECTRICAL MOTOR SHOP? THANKS ERIC
Zeb
11-22-2003 17:57:43
 Re: GENERATOR QUESTION in reply to ERIC, 11-21-2003 14:50:40
Eric I have a 46 H that has lights and I changed it to a hand crank. I run the lights with just a generator no battery and no voltage regulator.Run one wire to the lights and the other from the field terminal ground to the frame somewhere. I don't even use a light switch. I have the 3rd brush adjusted so that at low idle the lights aren't on until I give it more throttle then they come on and once they're on I can idle it down and have lights. They are brighter the faster the engine runs and at normal operating speed they work just fine too. It is a 6volt gen. but I use 12volt bulbs. Have your gen. checked to make sure it is working and then run your 2 wires and you're all set. I have no problem driving at night with mine so it should work for you. good luck Zeb.
Paul from MI
11-22-2003 06:32:38
Eric,
The system will work much better with a good working battery. Suggest you look for a small 6V motorcycle battery. Not too expensive, but big enough to run a few lights at idle. Also much easier to mount in limited space.
Paul
John T
11-22-2003 08:40:17
 Re: Re: GENERATOR QUESTION in reply to Paul from MI, 11-22-2003 06:32:38
Ive accidentally fried some of those small batteries. If you charge them, have a controlled charger you can set for a low amp rate so they dont boil over the acid and/or warp the plates. They are designed for the small alternators that may only put out 5 amps or so.
John T
Clooney
11-22-2003 07:19:08
Paul, the problem with a motorcycle battery [especially a 6 volter] is they can't take a heavy charge. An 18 amp hit from that generator at full output would soon kill it.
~He might be able to make it work with a 12 volt motorcycle or garden tractor battery & setting the 3rd brush back to tame down the generator's output. At 13.7 volts the generator could probably only muster up about 7- 9 amps & by adjusting the 3rd brush to lower the field strength that could probably be lowered to 3-4 amps. A small 12 volt battery could probably live with that....
[email protected]
buickanddeere
11-22-2003 07:09:17
Even a battery pack and nicad batterys from Radio Shack can be mounted anywhere out of sight and not leak.
John T
11-21-2003 16:18:28
Yep Eric, as Clooney pointed out below, hooking up a belt driven generator with a Voltage Regulator strapped on it isnt any big problem, but the lack of an energy absorbing and energy storing battery would be. Without it, I just see some lights (maybe 2 or 3 or ?? six volt lamps in series???) that would be dim at low RPM then bright at max RPM. You may be able to use a variable resistance rheostat of some sort to regulate field current to produce the right output to operate whatever combination (maybe 2 or 3 in series) of lights works at say Wide Open Throttle, but it dont sound very practical to me without a battery, unless you have one of the regular and equipped generator/light systems.
If you just have a 6 volt generator and its 3 wire Voltage Regulator, its FLD terminal is wired to the Field post on the generator and its ARM (Or GEN) terminal to the Armature post on the generator, with the BAT terminal being the output to charge the battery, but if the BAT isnt hooked to a real battery and unloaded, I cant guarantee what may happen if hooked to a light wired between it and the generators case???
Sorry, I dont have any good answer for this one.
John T
F-I-T
11-21-2003 17:05:35
 Re: Re: GENERATOR QUESTION in reply to John T, 11-21-2003 16:18:28
John T & Clooney:
My dad used to tell how they put lights on their hand start '36 "A" and '40 "H". They mounted a generator (probably from an old car) and wire it to run through a "dead" battery. Apparently, by pushing the current through the battery, they could get a realtively pure 6 volts, and it served to cushion any over-voltage from burning out the lights. I've never tried this theory, but many of my uncles said, yup, they put lights on all sorts of things and just used a worn out battery for a buffer. Dad said when you shut down the engine, the lights would slowly go out. Perhaps this is a time where this could be a fix for this fellow.
Also, he could try one of the solid state voltage regulators, maybe mount one at each lamp. The one I have been most familiar with is an old Nat'l Semiconductor type LM309K. There are other models with different output voltages. You could push anywhere from 8-25 volts into an LM309K and get a pure 5 volts out. It might take several units to cover his lamp load.
Just some thoughts.
Frank
John T
11-21-2003 18:06:55
 Re: Re: Re: GENERATOR QUESTION in reply to F-I-T, 11-21-2003 17:05:35
Yo Frank you Guru you. So long as the battery isnt dead shorted out and is still conductive across the cells (has electrolyte and not shorted) sounds like she ought to serve as a stabilizing load bank. If the VR is working properly, it ought to keep the gen from overheating, only problem I can envision is the gen may be workin its tail off always at max rate if the battery is real bad yet still takes current. However, at low RPM with lights on the gen has to produce its max anyway (which the VR and/or 3rd brush should regulate) even with a good battery, and thats no problem.
Im not sure what effective load a solid state regulator would place on the generator ??? Any others or the good Clooney man know its input resistance and power dissipation rating (depends on its specs I guess DUH) They would still need a high enough voltage input and the lights would then come on full at a certain RPM but stabilize if they (regulators) match up to the gens output. Thats almost too "electronic" for me and I have no specs on any of them rascals.
Sorry I forgot I already met you, but if it was at the JD 2 Cylinder Expo in Waterloo Iowa (Hawkeye College), now thats been a while. Heck, even if it were the last GOG (2002) thats still been too long for this old brain of mine.
You gonna be at the 2004 GOG??? I will try n rememebr if I meet you again lol.
John T
Clooney
11-21-2003 18:47:24
 Re: Re: Re: Re: GENERATOR QUESTION in reply to John T, 11-21-2003 18:06:55
John/ Frank, per his E-Mail he doesn't have room to use a battery... He's not even sure the generator is any good. [will know after some tests]
~I was thinking of a solid state v/regulator but with that generator putting out such a variable voltage not sure how it would react... Years ago I used a zenier diode & a 100 resistor to dump excess to ground for use on a motor cycle that I removed the battery from. That allowed the light & tail light to still function but the charging system was just a small winding under the flywheel... Not sure that would work with an 18 amp generator..
F-I-T
11-21-2003 19:45:03
 Re: Re: Re: Re: Re: GENERATOR QUESTION in reply to Clooney , 11-21-2003 18:47:24
Guys:
That's the really cool thing about those solid state regulators...you can vary the input voltage pretty hard and fast, and they put out a very pure dc component. Now, 309k's were only good for about an amp, but they are dirt cheap, and you can bundle them in little air cooled box and parallel up a goodly bit of current capability.
Pick yourself up at Radio Shack someday, and hook it the generator output, hook up your multi meter and cmove the engine speed around. I think it might be a simple fix.
I always thought that story about the old timers using the battery as a watt-accumulator was a pretty neat trick. I know he said the kit from Deere was close to $20 in 1937, so they headed to the junkyard and had lights going that night.
Pretty ingenious, I thought.
Clooney
11-22-2003 05:04:36
 Re: Re: Re: Re: Re: Re: GENERATOR QUESTION in reply to F-I-T, 11-21-2003 19:45:03
Frank, I think we have some LM 309's at work.. We also have a few 0-100 volt variable power supplies.. If I get a chance I will hook a few LM 309's in parallel & see if they can be powered in parallel & still hold a decent combined voltage into a load while I vary the power input.. If that works it sure would be the easy way to go.... I think we also have some LM 323 or 323A [can't remember], I believe those are a little higher amp output. Problem is 5 volts out won't really produce a lot of light from a 6 volt bulb..
~On the 36 "A" & 40 "H"...They must have driven the generators from the clutch pulley as neither tractor came with a fan pulley from the factory. [probably the reason the Deere kit was so expensive as it would have also required a new fan, fan clutch, & the later pulley]...
[email protected]
F-I-T
11-22-2003 18:56:12
 Re: Re: Re: Re: Re: Re: Re: GENERATOR QUESTION in reply to Clooney , 11-22-2003 05:04:36
Clooney:
Yes, the 5 volt regulator is certainly too low for the 6 volt lamps. I have just always used those on 5 volt logic circuits, but I have used the LM78M12 for 12 volts at a half amp a time or two. I think generally the input voltage can go as high as 35 vdc. There is a LM123, 3 amp package that needs 7.5 vdc minimum input voltage. I always thought that if I changed made a '70'D into 12 volts for some reason, that that's how I would handle the pony ignition. I just don't like those wire resistors.
Here's a good table of the Nat.Semi offerings. You can get them pretty cheap if you buy 1,000 at a time!
Clooney
11-21-2003 15:45:21
Eric, that 1101390 generator puts out about 15-18 amps @ around 7 volts - at 2000 RPM..
~I you want to install a 6 volt battery & some type of voltage regulator you won't have a problem running a light [or even more than one].
~Now if you want to just use the generator & a light without a battery you will run into problems..That generator is probably capable of 18+ volts open circuit & could probably pop a 6 volt light like a flash bulb at over 2000 RPM..
~If you are willing to risk a few light bulbs, & play with the 3rd brush adjustment, & fool with the field ground resistance, it could be done.. You will end up with a light that flairs up at higher than rated RPM's & a light that goes almost completely out at idle..
~It is possible to use a generator & light without a storage battery but will be difficult to set the system up to give any usable light at anything but a fixed high RPM..
~There was a lights only [without battery ] kit available for the old Deere "D" but if I remember correctly it ran the generator off the clutch pulley & used more than one light..
~That generator field draws about 2.5-3 amps at 6 volts so you could install a wire wound adjustable rheostat in the field circuit to ground, then play with the 3rd brush position to see if you could get a 12 volt sealed beam light to light enough to use at night & still not burn out at wide open throttle..
~Let us know exactly what you have in mind & John T & I will try to help you figure it out.. It might be a lot easier to just use a 6 volt lantern bolted to the back of the tractor & install a new battery once in a while...
[email protected]
ERIC
11-22-2003 10:41:59
 Re: Re: GENERATOR QUESTION in reply to Clooney , 11-21-2003 15:45:21
YOU GUY'S ARE PUTTING TO MUCH THOUGHT INTO THIS. I CHECKED THE GEN. AS YOU SUGGESTED AND IT WORKS. WHAT NUMBERS SHOULD I LOOK FOR? OUTPUT OFF OF F OR A TERMINAL'S BACK TO GROUND.RIGHT NOW IT PUTS OUT (GROUND TO TRERMINAL F) 7 TO 8 VOLTS.
John T
11-22-2003 12:29:41
 Re: Re: Re: GENERATOR QUESTION in reply to ERIC, 11-22-2003 10:41:59
Eric, I cant help puttin too much thought into questions, its a curse lol being an engineer and a lawyer. We cant help ourselves to over analyze everything. Like Clooney says, the Armature NOT the Field post is the generators output. With a battery in the equation, the better the Field is grounded (like a dead short) the more current it draws, and the more output the Armature post supplies.
If you just wanna try it out not using any battery, I suggest you wire at least three 6 volt lights in series and see what they do at RPM, then add more lights if too bright and burn out or less if they are too dim.
The Over Analyzer,,,,, ,, John T
Clooney
11-22-2003 12:16:04
Eric, you don't measure the output at the [F] terminal..[that's the field]
~If you have it mounted on the tractor, start the engine & run it at wide open throttle, then short the [F] post [smaller of the two] to generator frame & measure the voltage at the [A] post [larger of the two] depending where the 3rd brush is set the voltage should be over 15 volts..
~The generator's output should vary by how well the [F] post is grounded.. The more resistance between the [F] post & ground the less it will charge..
~There should also be a 3rd brush inside the rear of the generator.. It is movable & the more it is moved in the generator's rotational direction the more the generator will put out..
~It's difficult to test a generator without hooking it to a load [like a battery or resistor] .. Open circuit generator voltage can be deceiving..
~To really give that generator a true test you will need to hook the generator's [A] post to a load & charge it into a load [like a dead battery] .
[email protected]
