4010 gas JD Carb Float Setting
L Bryan
11-21-2003 09:58:23
Does anyone know what carb a4010/4020gas would have the #on tag AR45162/below that13430 I am trying to find float level and float drop settings . LB
david val
11-22-2003 01:10:17
 Re: 4010 gas JD Carb Float Setting in reply to L Bryan, 11-21-2003 09:58:23
acc. to the # it's a zenith carb. my (old) book says that when inverted, distance between bottom of float to float base surface,(without gasket) should be 1-19/32 inches. it also says that if more then 1/16 then spec, to replace float.
david
L bryan
05-15-2004 08:58:48
 Re: Re: 4010 gas JD Carb Float Setting in reply to david val, 11-22-2003 01:10:17
Have a Question On a zenith carb is the load setting screw in the eletric solniod shut assy.also which notch on the accerator pump rod is the right one three to choose from. Help would be great!!!
