hey wayne in tn
andrew
11-21-2003 09:42:30
Wayne where is the best place to find ingtion parts for my mt. I need a coil, dist. rotor and swtich. also need a gas cap old one leaks real bad. no one web site or vendor i've called seems to have all the parts. Thanks in advance for the help.
Henry J
11-21-2003 18:31:21
 Re: hey wayne in tn in reply to andrew, 11-21-2003 09:42:30
Andrew
I took my ole rotted out gas cap into NAPA and they produced one that looked exactly like the old one. My neck on the tank was good so I didn't have a wear problem there.
Wayne in Tn.
11-21-2003 14:07:56
Andrew, I get ignition parts, such as points, condenser, rotor, coil and dist. cap, at my small town auto parts store, it is a Carquest. If you are needing the ignition - light switch. That will have to come from Deere or find a good used one. I think they are over 50 bucks at Deere? As to the gas cap, an auto parts store may can match it. I don't know what Deere sells for a replacement cap, I have not had to buy one in a long time. You might try making a gasket and adding it to the one on your gas cap, to stop the leak. I have done that before with success.
