720 taper loc flywheel
arnie1968
11-21-2003 07:15:42
Any suggestions on removing a taper loc flywheel?
I have soaked it with pb blaster, Heated the flywheel around the hub, Devised a puller of sorts to pull from the outside of the flywheel putting pressure against the crankshaft, not to mention constant hitting with a hammer and a considerable amount of foul language. Nothing budges. What now?Do you need to do anything with the sleeve? I was told to tap the end of the crankshaft and the flywheel should pop loose.
I am at a standstill.
Thanks for any help
HARRY
11-22-2003 18:04:48
 Re: 720 taper loc flywheel in reply to arnie1968, 11-21-2003 07:15:42
I need a taper lock for a 70d--- Where is the best price in SE US ?
MIKE HANLEY
11-21-2003 16:23:07
PER ithe WRITTEN instructions that come with the loc tite flywheel. Lossen the big nut till it's past the threads. Then have someone wearng gloves hold a thick flat piece of steel flat against the big nut and hit the steel plate with a 16# maul. We use took ours off q 730D that has been on since 1987. Took three hits and it poped off. When you put it back on. Hit the ribs with the 16# maul ONE time. Thigthen nut. Hit again ONE time tighten nut. Keep this up thill the nut nolonger tightens.
MIKE HANLEY
11-21-2003 16:31:12
 Re: Re: 720 taper loc flywheel in reply to MIKE HANLEY, 11-21-2003 16:23:07
Dang I forgot the most imporant step. Before hitting the big nut (removal) or the ribs (Installing) take a bottle jack between the tire and the bolt on the cluch that holds the cluch to the crankshaft.
ChuckW
11-21-2003 11:07:54
the large square nut needs to be loosened it not removed. Per the previous post get someone to help you and by all mean chain the wheel to a boom pole, or other good lifting device. If this thing gets loose off the crankshaft you'll never hold it and could get seriously hurt. As I recall they weight a couple hundred pounds. The sleeve is acting as a wedge to the inside and like the other post, wedge behind the wheel then use a jar force on the crankshaft. Don't hit with metal and bugger up the threads, use an oak board or block.
Mike M
11-21-2003 09:55:47
I have had a couple that stuck on me.
First, did you loosen the big 4 inch or so square
nut ? I think I left it on but loose so if flywheel did budge it wouldn't fall off. I think this is a two man operation so get a friend. I think I pryed out on outer edge of flywheel or drove some wooden wedges in between main case and flywheel then with a block of wood and sledge hit on the square nut. Worth a try unless you did this allready.
