John Deere 430W Lift rebuild???
Justin
04-13-2001 07:22:36
My 430W leaks a fair amount of hydraulic oil out of the seals on the main unit under the seat. The lift works good, it just leaks. Should I attempt to rebuild this unit or should I take the assembly off and take it to a John Deere service center? Or should I just add hydraulic fluid when needed. (I do not use the tractor very often.) What would rebuilding this main unit cost?
Thanks.
ET
05-16-2006 09:30:52
 Re: Bolting main case to rear axle assembly, '51 B in reply to Kurt_JDB, 05-16-2006 05:52:38
All new bolts would be cheap insurance and put your mind at ease.
Bob M
05-15-2006 19:25:27
 Re: Western NY 2 Cyl Club Spring Plow Day (photos) in reply to Gwiz, 05-15-2006 19:19:37
5 bottom trailer plow - 5 x 14" I believe...
