4010 3 point
ERIC D.
04-12-2001 20:37:12
i have a 4010 diesel with a 3 point, i was curious if there is a way to speed the raise rate of the 3 point hitch. it has plenty of lifting power but is extremly slow at lifting. amother question,
is there anything i can to to reduce the noise that the hydraulic pump makes, it is full of fluid and makes an echoing sound through the lines.
Thanks, Eric
Sam S.
11-03-2006 19:59:52
 Engine Shop in Mpls? in reply to
john2510-3020
04-13-2001 05:24:54
 Re: 4010 3 point in reply to ERIC D., 04-12-2001 20:37:12
there should be a little lever under the seat by the dip stick to check your hyd. oil. it should have the letters l ld and d on it the l is for load control ld for load and depth d is for depth control. try moving it to these diffrent positions and see whish one you think is faster.we use ours on either l or ld if thats any help. i hope htis helps. john
