70 D power steering, will it work on a 70 Gas
ljs
04-12-2001 19:24:10
I have a 70 gas that does not have power steering. I have located a powersteering unit off a 70 Diesel for $100. Will it fit on the Gas tractor or is the fanshaft assembly all diferent.
Thanks
Lynn
capt rag
05-16-2006 03:36:26
 Re: powershaft clutch in reply to Glen in TX, 05-15-2006 22:16:21
thanks for your help. two cylinder plus is my usual vendor and they are saying July-they have the same source.
Putt Putt
04-13-2001 06:05:43
 Re: 70 D power steering, will it work on a 70 Gas in reply to ljs, 04-12-2001 19:24:10
Hello Lynn
It looks like you�ve got pretty smooth sailing on this one. There was no differentiation between gas, diesel or even LP for the 70 model. There wasn�t even anything different between the row crop and standard models. There were some evolutionary changes at serial number 7039773 (pump) and 7031230 (valve, pedestal, steering spindle, etc). These changes shouldn�t affect you as you are doing a complete swap. Just be sure to get the whole thing. It�s probably a pretty good sized job but after it�s done you�ll thank yourself. Power steering makes a big difference in a 70. Good luck. Let us know how it turns out.
Putt Putt
Mike M
05-15-2006 07:54:16
 Re: 35 B JD Hand Crank Problems in reply to Jak, 05-15-2006 06:46:45
Some are naturally hard starters. Sometimes if you do alot of trial and error you can help them out. Shuting the gas off and letting them run out sometimes helps restarting. Some need little throttle some need alot some need only half choke.
Then every so often you find one like I had last year and sold. It was an old B like yours. It had been sitting for years no one really knew the story. I checked the spark,had some,dumped gas in it gave it choke and some throttle and it soon fired up. Ran it around some but it was missing a tire on one side so couldn't really run it much. This thing would beltch out blue smoke and throw dropplets of oil out the stack. The engine had to be shot,but every time you wanted to start it there was no problem getting it going in just 1 or 2 seldom more turns. I wonder if it is still going to start as good after it is fixed ? Some just start and run no matter how bad they are !
grandads A
05-15-2006 08:11:13
 Re: You must Read!!! Different or Disgrace? in reply to A John Deere, 05-04-2006 18:34:23
I have a 47 A and have wonderd what it would look like if it were all chrome with the top of the cowel painted flat black like an old all metal aircraft.
Kurt_JDB
05-15-2006 19:22:49
 Bolting main case to rear axle assembly, '51 B in reply to A John Deere, 05-04-2006 18:34:23
