Jd 730 oil pressure
jd730d
04-12-2001 15:51:49
i have a jd 730 diesel that is only producing 20psi oil pressure at 1000 rpm engine has been gone through and the oil pressure does notchange when doing the adjust ment and help would be appreciated thanks jd730d
Glen in TX
05-15-2006 08:17:26
 Re: 1950 JD A oil pressure too high in reply to ironhoarder, 05-15-2006 08:04:16
The I&T JD-4 discusses this at about paragraph 120. Get a good oil guage with number readings and see if you have 10-15 psi reading. Adjust the screw where you have that and yes CCW should decrease pressure. If that doesn't work start looking for a plugged filter or obstruction in the oiling system.
