JD 4230 Questions
Duane Laabs
04-12-2001 15:31:55
I am considering purchasing a JD 4230 with a Sound Guard Cab. It is the Quad Shift with Dual Hydraulics and has not yet been used with a front end loader. It has 5800 hours on it.
I am wondering where it was manufactured? How can I tell?
Where can I go to get a manual for one?
How is this tractor for use as a snow thrower?
Any other comments on that particular tractor would be welcome.
Jak
05-15-2006 10:19:21
 Re: 35 B JD Hand Crank Problems in reply to JDBert, 05-15-2006 08:55:33
We'll try that tonight.
CharlieB
04-13-2001 08:50:26
 Re: JD 4230 Questions in reply to Duane Laabs, 04-12-2001 15:31:55
We bought a new 4230 in 1975. It's still here, with the usual repairs, nothing out of line. Ours has an MW turbo kit. Deere mechanics have told me that this model has the oil pump running off the camshaft, so this should be waatched closely or replaced at 5-6000 hrs. We did this.
Dan
04-12-2001 21:05:48
the 4230 was a good tractor, it is rated at 100 hp and should be very adequate for a snowblower, depending upon size. they used a naturally asperated 404 Diesel engine, same one as on the 4020. Sound guard cab was about the best made at the time. They were manufactured at Waterloo Iowa I believe, best place to get a manuel is through JD though I have seen them on Ebay also. Get a service manual and parts manual also and you will be glad you did. I worked for a JD dealer at the time these 30 series tractors were new, there were initial problems in the permaclutch, but JD replaced them on warranty along with some transmission gears. Not many other problems that I know of.
