JD A BIG PROBLEMS PLEASE HELP
JARED
04-09-2001 19:17:03
Hi guys,
I acquired a 1944 JD A about 1/2 year ago and it has never ran properly since then, i took off the carb and cleaned it out but that didnt help. So now i have moved on to working on the magneto but know nothing about them.....right now it has a "Super Chief" model "SP" on it and it keeps on backfiring through the carb no matter what adjustments we make to it or the carb. I also have a WIKO model X that i havent tried yet but i dont think it even fits, it just came with the tractor when i bought it. So if you could give me any tips or anything it would be of great use cause i cant wait to drive this beauty. Thanks..... ...Jared
Jim
04-10-2001 20:17:12
 Re: JD A BIG PROBLEMS PLEASE HELP in reply to JARED, 04-09-2001 19:17:03
Had a JD 60 with same problem. The camshaft bearings were bad. Also check to see that the heat exchanger is set either on hot or cold but not in the middle.
Pappy
04-10-2001 18:51:59
Does this tractor actually run, or are you just trying to start it? Give more information if you can.
BobTGS
04-10-2001 07:45:53
Backfires through the carb, could be a sticky intake valve. Bob from Triple G Service.
JG
04-09-2001 19:23:57
Jared, sounds like your A isn't timed properly if you're getting backfire through the carburetor. Check you timing before you go further into the engine/ignition system.
Jim N
04-10-2001 07:54:56
 Re: Re: JD A BIG PROBLEMS PLEASE HELP in reply to JG, 04-09-2001 19:23:57
Did you switch the plug wires?
