3020gas
john
04-09-2001 18:39:31
have a 3020 gas had the head acid washed and a valve job done put it on and wont start. it cranks and if you shoot ether to it it tries to run but backfires through the carb. do i need a new carb? this one has been rebuilt twice and i have only had the tractor for 2 years. it has a zenith...i was woundering were i could get a new rebuilt marvel schebler or zenith carb at? when back-fireing throug carb. it catches on fire. so what should i do let it go ahead and burn? john
Glen in TX
05-15-2006 17:00:46
 Re: Van Brunt/john deere grain drill color questio in reply to jubilee johnny, 05-15-2006 11:34:29
JD green on frame and box unless box is galvanized, yellow wheels, yellow seed box lids and black disks.
Bob Collins
05-15-2006 16:59:43
 Re: G top ring groove problem WMW?? in reply to 1eyedwillie1, 05-15-2006 05:55:46
1 eye, I know you are visualizing the top (closed end) of the piston as being placed on the bottom and obviously that won't work. What Will meant was the piston was rotated 180 degrees in the bore so that any piston pin offset was toward the "wrong " side of the cylinder. The offset is intended to balance the power force against the top of the piston and equalize cylinder wear, when offset the other way some power advantage is realized at the expense of wear and piston slap noise. In this case there can be spark plug blocking too unless a notch is provided.
Gerald J.
11-03-2006 20:17:28
 Re: 3010 with 35 loader?? in reply to Hayfarmer, 11-03-2006 19:36:33
third party image
3010 is closed center. Its not hard to pick off power and return. Hydraulic power is available at an elbow right at the brake pedals, return to the transmission oil cover. I like to have a flow restrictor valve to keep the loader under control. For my loader 5 gpm is plenty and I want to leave main flow for steering and brakes.
My connection manifold on my 4020 is shown at>Link
I>Link use the second port for a three point backhoe.
Gerald J.
john
04-12-2001 19:06:22
 Re: 3020gas in reply to john , 04-09-2001 18:39:31
i have checked the valve adjustments 4 times come up with the same thing..... but i guess i'll do it again
Plug wires reversed?
04-12-2001 08:36:13
It's firing when the intake valve is open. I'd guess it to be out of time, valves not closing due to improper adjustment or plug wires reversed. Sit down and think this out before you burn up a good tractor.
buckeye al
04-12-2001 05:32:51
Would seem it has to be a timing, plug wire or valve adjustment problem. Since the valves were the most disturbed by the surgery, I'd look there first. Perhaps you have several intake valves that are still open during the compression and power strokes. That would make it have poor compression, reluctant or impossible to start, won't take in enough fuel via carb & choke so you shoot ether to it & it fires back through carb, catches fire & doesn't run. I think I'd start at the top & check the valve adjustment.
Good Luck.
john
04-11-2001 20:20:56
ok but i think you guys are missing my main question!!!! should i just go ahead and let the piece of s*&% burn? it has done nothing but eat my money and laught at me..... john
Some like it hotttttt!
04-11-2001 21:45:00
 Re: Re: 3020gas in reply to john, 04-11-2001 20:20:56
Maybe! If the price of gas goes up this summer like they are saying then you won't be able to afford to run it anyway. However, you might wait to burn it until winter then you can use it for heat.
john
04-10-2001 18:34:52
no i did not have the distributer off but was woundering if i should retime it just in case? i have already adjusted the valves. could it be 180 deg. off by some chance?
twopop
04-11-2001 11:06:01
 Re: Re: 3020gas in reply to john, 04-10-2001 18:34:52
if the engine was running before you had the head work done,and everything being the same there should be no reason for it not to start.if i remember right, unless you took out the oil pump, you cant put the distributor in wrong.if you had the plug wires off the distributor cap then you could have the wires on wrong.bring it up on # 1 compression and check the rotor position and direction of rotation,to check firing order.you could also have an air leak in the manifold gasket.
JD Mech
04-10-2001 22:14:08
If the tractor was running before you worked on it and the distributor has not been moved I would say the timing is o.k. You could double check it if you wanted to but I think it would be a waste of your time.
G Taylor
04-09-2001 21:32:41
Possibly valve lash adjustment required.
twopop
04-09-2001 20:23:28
the backfiring is caused by a valve being open when spark occurs.i believe you should recheck the firing order.as far as the carb is concerned,i cant help
I think I know?
04-09-2001 21:08:06
 Re: Re: 3020gas in reply to twopop, 04-09-2001 20:23:28
By some chance did you have the distributor off. I,m thinking it has to be timed with the cam drive gear on top of the oil pump.
