JD H oil level check and capacity
PC
04-09-2001 05:02:45
I need to find the oil level check on an H and its oil capacity (quarts of engine oil). What type of oil is a good summer oil?
HMan
04-09-2001 19:40:42
 Re: JD H oil level check and capacity in reply to PC, 04-09-2001 05:02:45
PC, If you look just below and slightly to the front of the flywheel you'll see an oil check plug. Fill it through the crankcase breather at the front of the rocker cover till it runs out the check plug. About 4-5 quarts best I remember. If it's not a freshly rebuilt engine try straight 30w or if you're a mulit-grade man 20-50w. HMan
