Donaldson Air Cleaner
Toaster
04-08-2001 20:06:49
Hey guys, how do I get into the cannister of my Donaldson Air Cleaner so I can clean the wire mesh screen? Do I have to drill out the rivets or spot welds on the bottom of the cannister? How do I know if it is dirty, or is that a given? Thanks.
G Taylor
04-08-2001 20:13:16
 Re: Donaldson Air Cleaner in reply to Toaster, 04-08-2001 20:06:49
Drill the spot welds from the inside. reassemble with JB weld, brazing, rivits or bolts if reusing the mesh mess. Better to cross reference the Fram catalog & stuff a dry airfilter in there. Less restriction & cleaner air. If the tractor has been run, there is a clogged mess of muddy oil lurking within.
JD70Jim
04-09-2001 16:27:14
 Re: Re: Donaldson Air Cleaner in reply to G Taylor , 04-08-2001 20:13:16
What tractor is this air cleaner on?
Toaster
04-11-2001 19:41:45
 Re: Re: Re: Donaldson Air Cleaner in reply to JD70Jim, 04-09-2001 16:27:14
It's on a '52 JD AO, SN 280743. I've cleaned off enough oily dirt to pave my driveway, but I haven't gotten inside yet.
