JD 'A' won't idle
randy
04-08-2001 18:45:58
Bought a 1950 A, rebuilt carb still won't idle.
Governor doesn't respond very fast either. Need help.
Keith
04-10-2001 19:55:42
 Re: JD 'A' won't idle in reply to randy, 04-08-2001 18:45:58
If you haven't checked the ignition points make sure they're good and clean before you spend a bunch of time on the carb again. Marginal points can seem to work OK at higher speed but cause misfire badly at idle speeds.
clooney
04-08-2001 19:04:06
Randy, you need to go back through the carb & pull the brass plugs then clean the idle, fuel & air passages with a piece of .035 welding wire or the proper sized drill bits, then make sure the throttle shaft bushings are flush with the inside of the throttle bore. Just using solvent & compressed air will NOT clean a DLTX carb because of the internal passage rust problem.
