HP rating on 2130
Steve Addington
04-08-2001 11:55:13
What HP is the 2130 diesel rated at? Any coments on this model good or bad? Thanks Steve
Bob W
04-12-2001 19:40:52
 Re: Re: HP rating on 2130 in reply to G Taylor , 04-08-2001 20:06:38
Yes the 2130 was/is a naturally aspirated 239 c.i.d. engine. The hi/lo was a valuable feature. If you are looking at one take a minute if you can and remove the hydraulic oil filter and check in the bottm of the cover. Any amount of silver/gray material indicates possibly that the brake lining has desintegrated and there is steel on steel happening in the brake area. On the other hand,my in laws had one of these tractors, a 75 vintage I believe,and we all loved it. It was the most comfortable tractor I can think of to this day. This one had 18.4X 30 rears on flanged axles and planted thousands of acres with an 8 X 30 7000 JD planter. Many people didn't think it would do this but we found it made a great combination.
Bob
05-15-2006 08:02:46
 Re: Another 12 volt conversion failing JD Model M in reply to moveme, 05-14-2006 17:57:41
You should have an "idiot light", a resistor, or a diode in the lead from the #1 terminal on the alternator to the coil, 'cause if you do get it revved up and charging, without one of the afore mentioned components in that lead, current will feed back from the alternator's #1 terminal to the coil, causing the engine to keep running when the ignition is switched to "OFF".
Third Party Image
Bob W
04-12-2001 19:40:18
