520 under load
Chuck
04-07-2001 17:42:34
I have restored several tractors and recently another 520, rebuilt the power steering and lift works fine, also rebuilt engine. I have noticed that the tractor appears to be taking on some load, like hydraulic pressure...is puzzling, recheck the PS and it works great....any opinions....
DP
04-08-2001 08:16:54
 Re: 520 under load in reply to Chuck, 04-07-2001 17:42:34
Hi Chuck, one other thing you might check, if the timing is set too slow it will run alright, but sound as if it is under a load. You might see that it hasn't moved for you.
clooney
04-07-2001 18:04:42
Chuck, I assume you have shut the PTO main lever & Power-trol pump off & tried it? If ok there, how much oil pressure are you running, less than 20 psi? See how easy the engine is to turn by hand when it is warm & off? Check end play on the crank? need .005"+ (A tight engine bearing will occasionally act like a hydraulic load)
Chuck
04-07-2001 20:27:54
 Re: Re: 520 under load in reply to clooney, 04-07-2001 18:04:42
Clooney, am running between M/H, set the regulator...I did put in new old stock pistons, however the cylinder had some wear, I checked the bearings....Installed 10/40 oil...maybe I just need to get it broke in some, I ran it under load and it seems to want to be a little livelier, guess I need to put in on a plow or bushog....
