620 Power Shaft Leak
Dick
04-06-2001 06:50:32
Fluid is leaking out around the power shaft. I imagine the seal needs replacing. However, the parts book shows BOTH steel AND paper shims, rather than gaskets. The JD dealer doesn't know which is correct, and is it a matter of taking off the housing, removing and replacing the seal and shim or is is more complicated?
Thanks for the help. Dick
Steven
04-06-2001 16:42:28
 Re: 620 Power Shaft Leak in reply to Dick, 04-06-2001 06:50:32
The steel shims are for adjusting bearing end play,(pre load) if your bearings are loose you will want to remove some. YOU WILL NEED AA 2296 R oil seal. A 5688 R gasket. And get a I&T Shop Manual JD-16 It will help you allot.
