John Deere 435D
Charles Cue
04-05-2001 05:48:30
Does anybody have any information on this model? Is there problems with this model since it was only built for 2 years? Does it have a lot of power or gutless?
G Taylor
04-06-2001 10:13:36
 Re: John Deere 435D in reply to Charles Cue, 04-05-2001 05:48:30
Built for 11 months from March 31st 1959 to Feb 29th 1960 in 4626 units. Built as the 445 in Argentina until 1970. It's a 33HP tractor so it's gutless compaired to a 50HP tractor & a powerhouse compared to a 18HP tractor. Most problems were operator error in service & operation. The tractor is female without a doubt. Treated right & if in a good mood they are great. Most operators didn't know the 2-53 was a detuned "S" series with 17 to 1 compression. After killing the battery they would wrap a chain around the front axle & break it while pull starting. The use of ether through the oilbath aircleaner was another common way to ruin the engine. If they got it started the tractor was often overballasted & used on heavy draft loads & lugged hard. The ring & pinion would fail rapidly if cheap or if contaminated trans lube was used. Rebuilders today often mistakenly use the "S" series parts instead of the updated "N" series rebuild components.Valve springs, blower seals, pistons, sleeves etc are all improved. The oilbath aircleaner often isn't completely disasmbled choking air supply. Now the rebuilder puts oversize injectors in without restoring the piston spray cooling. Soon the smoke & soot will ruin the engine if the pistons don't score 1st.If there isn't a high RPM run away. All these problems can be avoided. There are several past articles in. greenmagazineonline.com & Rummey's site.
Sam
04-05-2001 17:33:27
The 435 is a 430W factory equiped with a 2-53 Detroit Diesel engine, mechanically the same tractor as a 440ID. Generally the 2-53 is a little hard to start and has to be reved up to maintain good power. The engine has a "Jimmy diesel whine" that is distinctive. Generally not a good tractor for "lugging" operations. On the plus side parts for the 2-53 are comparitively inexpensive. I have a 440ICD (a crawler with the 2-53 engine).
mike
04-06-2001 12:37:09
 Re: Re: John Deere 435D in reply to Sam, 04-05-2001 17:33:27
They might look the same as a 430,but there
are several differences including,Ring and
pinion,tranny gear ratio,and others.
dieoblo
06-04-2005 02:02:32
 Re: Re: Re: John Deere 435D in reply to mike, 04-06-2001 12:37:09
the 2-53 starts much better with two larger size injecters installed also jumps the horse power and luging power the other thing to rember about these those detroits are two stroke they derive
there power from rpm but fed enough fuel they start better and still run 2 gallon per hr. I own two of them one power shift 5 speed float seat etc. other not power shift wheel contact I will send PIC.
