2040 glitches
Le
11-20-2003 15:59:29
Had the new 2040 out today and ran into a few glitches.
1: Rear 3point hydraulics are week as S***! Stuck bushhog on it before we bought it to test and seemed like it worked fine. Tried to move some logs on a boom and it wouldn't lift them even at the closest point to the tractor. The front loader works fine. We put 1300lbs in the bucket and it lifted with no problem. Checked the fluid and with the rear end down hill it looked fine. I need to check it again on the level. I plan on changing the fluid and filter. Any other suggestions??
2: One of the rear wheels has a very noticible wobble when going down the road. My father was following me and said it looked like it was wobbling about 1.5-3". Any suggestions?
3: Are rear wheel weights availible? There is some fluid in the tires already and the tire service is coming tommorrow to top them off but it still seems awful light in the rear when using the bucket.
4: Are front wheel weights availible? Putting a load of firewood in the bucket helped alot but without it the front wouldn't stay on the ground when pulling. Has anyone balasted the front tires on their 2 wheel drive tractor? Any problems doing this?
5: Between the controls for the 3 point and the trans there is a little lightweight sheetmetal lever with about 6 detents. What the heck is it for?
6: How the do you get the hydraulics to stay in 1 place? It seems like I either have all the way up or all the way down nothing inbetween. If the lever is anywhere other than at the bottom they will go down then start back up.
Thanks
Le
Le
11-20-2003 16:27:03
 Re: 2040 glitches in reply to Le, 11-20-2003 15:59:29
Forgot to the left brake doesn't work. My guess is that I need to replace the brake pads. From reading some of the other hydraulic posts, it seems like the hydraulic system is somehow involved in the brake system. Could the weak 3 point hydraulics have anything to do with this.
I'm getting the Operators and Parts manuals and probably will be stuck with a I&T shop manual until I can scrounge up a used JD manual.
Le
david val
11-21-2003 02:54:26
 Re: Re: 2040 glitches in reply to Le, 11-20-2003 16:27:03
remove filter cup. oil in cup should be clean and clear. if it is, check suction screen for brake linings. if clean there is a leakage in the brake circuit that needs to be found.
the sheet metal lever is lhe load control lever. it should be on 'd' (or min) for every use other then 'in the ground' work (like ploughing). in 'd' you should have full control of rockshaft movement with the raise-lower lever.
david
Le
11-23-2003 17:47:10
 Re: Re: Re: 2040 glitches in reply to david val, 11-21-2003 02:54:26
I think there is a definate leak in the brake circut. Had the right Left side slowly ease to the bottom on me today.
Problem was I was on a downslope with an engine hung on the bucket and 2 more engines and building in front of me.
Le
Le
11-21-2003 20:12:23
I'm waiting on my books to come in. Where is the filter cup and can it be checked w/o draining the fluid?
If there is a leak in the brake circuit could this cause weak 3pt hydraulics w/o affecting the remotes?
The problem I was having with the rockshaft control was the lever would move to the up position and the arms would go up if it was not all the way down or I was holding the control lever in place.
