Head Bolts
KENW
04-03-2001 13:14:02
I am rebuilding a late model B and I don't what I should torque the headbolts or rod cap nuts to. Any help would be greatly appreciated. Thanks KenW
Steven
04-03-2001 15:51:56
 Re: Head Bolts in reply to KENW, 04-03-2001 13:14:02
Soak the cylinder head gasket in engine oil for five seconds and allow to drain for one minute before installation. install cylinder head gasket with smooth side toward cylinder black and use new lead washers under the cylinder head retaining stud nuts.If cylinder head or tappet lever retaining studs were removed, apply white lead or equivalent sealing compound to the threads before installing studs. Tighten cylinder head retaining stud nuts from center outward and to a torque of 96 ft-lbs for series B On all heat treated studs (dark colored studs) tighten the stud nuts to a torqie of 104 ft-lbs for series B Install connecting rods and caps wit munbers facing up Tighten connecting rod bolts to a torque of 62.5 ft-lbs for series B (FROM I&T SHOP MANUAL JD-4)
