JD model B roll-o-matic
Billy
04-02-2001 18:53:30
Could any of you tell me if putting a ROM casting from a 1950 (pressed steel frame) B on a 1946 (angle iron frame) would be a direct bolt on ? Thanks for the help
DonWis
04-03-2001 20:51:22
 Re: JD model B roll-o-matic in reply to Billy, 04-02-2001 18:53:30
Hi Billy I have a rollomatic front end complete in excellent condition if your interested that im told will fit model bs thru the early model 50s
Mike Aylward
04-03-2001 11:08:51
Billy, I'm not sure of this on a B, but you might just put the spindle out of the later B in your own tractor. I think the splines at the top might be different and they take a different sector, but you might do some measuring and see if they will work. There was a retrofit available for the older tractors to put ROM under them. It used the same spindle shaft and a ROM box under it. Hope this helps. Mike
BobTGS
04-03-2001 08:32:11
Billy, those two front ends have a differant bolt pattern.Bob from Triple G Service.
