Bare Engine Block Wanted For JD 544b Loader-414 cid
Pat Ringler
04-02-2001 16:43:28
I need a bare engine block for a JD 544b rubber tired loader.It is a 414 cubic inch 6 cylinder turbocharged diesel engine. I have several block #'s to compare to. Some older 9400 JD combines also had these.
david val
04-02-2001 21:32:47
 Re: Bare Engine Block Wanted For JD 544b Loader-414 cid in reply to Pat Ringler, 04-02-2001 16:43:28
newer 6068 engines, that are very common on ag tractors, are basically the same and the block should fit (maybe along with some other parts)
david
