Need Rec. - Stop Leak Antifreeze
Ken Reese
11-20-2003 12:42:22
What is recommended as the best stop leak product (brand/type)for use in an old two-cylinder tractor (1950 B)?
Is there a recommended brand of anti-freeze?
Thanks,
Ken Reese
Bill R
11-21-2003 06:55:04
 Re: Need Rec. - Stop Leak Antifreeze in reply to Ken Reese, 11-20-2003 12:42:22
Have had good luck with JB (Justice Brothers) Radiator stop-leak. Try to use that stuff on when I have to. Probably no water pump on that tractor so you'll have to give it a good workout and get it up to temp before the stop leak will circulate throughout the system.
Bill R
A // B // GW // R Diesel
chris
11-20-2003 19:19:30
Conklin has a great product call DIKE, once had a JD A with a hole in the radiator. The leak was very noticable, could actually see the water trickle out, poured in a can of dike, ran for a half hour and the leak was gone. Was a believer ever since and I don't sell the stuff either. chris matthies
Jim in NC
11-20-2003 16:27:02
I have had good results with Bars Leak in newer cars as well as older tractors. You can get at most places that sell auto parts.
Henry J
11-20-2003 16:02:17
I pamper mine with the non silicate antifreeze stuff and distilled water.
Hank
11-20-2003 15:37:19
Have had good luck with a product called Block Seal. Auto Zone and Discount Auto Parts carry it.
