I'm only guessing here, but I figure if I put an answer on here, someone will correct me if I'm wrong. I think it's probably built in Duluth, Georgia and the engine is probably a Yanmar. If not built in Duluth, then I'll guess Mannheim. If not a Yanmar, I'd guess some other brand. How's that for hedging my bets? Now, that should be enough for everyone to shoot at, eh? Some specifications from a December 1999 piece of JD literature: PTO hp - 40 SAE gross engine hp - 45.6 Rated engine speed - 2,300 rpm Engine - John Deere 3029D POWERTECH Type - Vertical, valve-in-head, 4 stroke diesel Operating range - 1,600 to 2,300 rpm 3 cylinders 179 cu. in. (2.9L) Aspiration - natural Bore - 4.19 in. Stroke - 4.33 in. Lubrication - Forde-feed, pressurized with full-flow filter Cooling system - Pressurized with centrifugal pump Number of main bearings - 4 Transmission - 8/4 SyncReverser Synchronized shuttle - Standard There, I've told you more than I know. Good luck, Stan
