JD 430 hydro. trans locking up
Ed Brown
03-30-2001 16:10:23
I recently purchased a JD 430 hydrostatic tractor, I sent it in for service, as luck would have it, it came back in worse shape than when I sent it in. They replaced a rear differential, upon returning it, it seemed to be ok. But the more I used it, the forward pedal kept getting harder to push and it makes a whinning noise which gets louder the harder you push it. I am totally devestated! If anyone has any ideas what would be causing this, I would be eternally grateful. Its supposedly still under warranty, but now I am losing trust in their mechanic. There were also other problems they neglected to fix, PLEASE HELP!! thanks, Ed
ps. It seems to me that the hydraulic flow is somehow being blocked, whether this is an adjustment on the pedal mechanism, I do not know. Could it be a blockage internally? they said they had to split the tractor to change the differential "gasket sealer?"
