730D questions
Poor Farm Jim
03-28-2001 18:10:18
Coming close to buying a 730D with factory wide front and 3-pt. The price would sound very good to you, but the tractor has high hours, banged up sheet metal and a taper lock flywheel, tires not the best. In the center of the flywheel cover they have welded on a cap (ugly I might add), I assume for additional clearance for the taper lock flywheel hub. Is this the case? Also, when the clutch lever is pulled back to disengage, just the weight of the lever wants to start engaging the clutch; the tractor will actually move if in a gear. Is this fixed by just adjusting the two screws on the pulley brake, or would I be looking at something internal?
