Bolt between the governor serial number plate ?
Mike W
11-20-2003 09:21:45
I have a 1946 Model "A" and there is a hex-head bolt and what looks to be a lock washer between the governor and the serial number plate that is leaking oil. I've looked through the parts manual and a "B" service manual and I can't figure out what that bolt is for. I'd like to stop the oil leak but I don't want to remove it if something is going to fall into the crankcase once removed. Could someone tell me what this bolt holds and a good way to seal the leak ?
Thanks,
Mike
WTW
11-20-2003 10:57:04
 Re: Bolt between the governor serial number plate in reply to Mike W, 11-20-2003 09:21:45
Mike, If this bolt takes a 3/4" wrench to fit it and points down from the top of case it is one of three retaining bolts that retains the cam follower housing to the main case. Housing is inside case and hangs from the top of case in front of camshaft held by these three bolts. The other two bolts that you cannot see are under the governor case and will hold this housing in place while you remove the one that is leaking. Clean the bolt with a wire brush and some brake clean and seal the threads with some number two permatex. That will fix your leak. DW
Clooney
11-20-2003 10:19:13
Mike, I don't have a parts break down handy but that bolt sure sounds like one of the bolts that holds the tappet shaft to the bottom of the upper crankcase.. If it is,, don't pull it out, but instead loosen it a little then use brake clean to clean the bolt & the surrounding area, then squirt some sealer under the bolt head & tighten it..
[email protected]
