B hard to start
Demo
03-28-2001 05:32:22
I have a 45 B. It is very hard ot start. Once it is running it sounds fine, no black smoke. Could it need carb adjust? It idles down nicely. Any ideas?
Gomer
03-28-2001 18:32:14
 Re: B hard to start in reply to Demo, 03-28-2001 05:32:22
I would suspect ignition or timing problems. If you have a magneto, I would start with it and be sure it is timed correctly, and is putting out a good spark.Carburetor adjustments can come later.
clooney
03-28-2001 15:12:46
Demo, it could be anything from old gasoline (old gasoline looses it starting ability because the easily evaporating parts of it have already evaporated) to a choke not completly closing (or the little trap door in it is missing) or the ignition system is weak. You can try adjusting the idle screw about 1/2 to 1 turn out to see if it starts easier. You could also have worn rings that won't build much compression until it is running & oil gets to the rings. Did this problem just suddenly appear or has it been getting worse with age?
gary
03-28-2001 11:41:20
Demo, Is it electric or hand start?
Demo
03-28-2001 13:43:46
 Re: Re: B hard to start in reply to gary, 03-28-2001 11:41:20
It is electric.
weiner
03-28-2001 17:28:12
 Re: Re: Re: B hard to start in reply to Demo, 03-28-2001 13:43:46
hard to start because missing 2 clyinders paint it red
