JD A Power Steering?
Tom
03-27-2001 06:13:41
Hello Folks!
I am going to install a 45 Loader on my 1944 JD A and would like to convert it to power steering because of the extra weight. Is this possible? Is there a factory or aftermarket method that works or am I dreaming? Thanks, Tom.
poorerbut...
03-27-2001 12:53:03
 Re: JD A Power Steering? in reply to Tom, 03-27-2001 06:13:41
Tom : Once in a while you can located a used
Behlen of Charlyn pump unit that mounts on the governor housing ahead of the mag. I've seen some
belt driven ps units (auto) run off the fan pulley
with a quart reservoir attached. The hard part is
finding the in-line steering (orbial motor) unit
that will couple up to the steering rod and match
the pump. If you manage to find two- holler loud.
I've got a fella that wants one, too.
ET
03-28-2001 05:45:13
 Re: Re: JD A Power Steering? in reply to poorerbut..., 03-27-2001 12:53:03
Use the power steering unit out of the shaft on an
old 55 combine.
