JD B blowing oil
Doug Delaney
03-24-2001 19:20:58
I've got a '49 B that is blowing oil out the exhaust...LOTS of it..I'm wondering if anyone out there has encountered the same and if I'm looking at rings or valve.
KK
03-25-2001 17:11:25
 Re: JD B blowing oil in reply to Doug Delaney, 03-24-2001 19:20:58
A FRIEND OF MINE PUT HIS OIL RINGS ON UPSIDE DOWN.
THAT LITTLE "B" COULD PUMP THE CASE DRY IN 20 MIN. AT AN IDLE. IT ALL WENT RIGHT OUT THE EX. PIPE.
clooney
03-25-2001 05:54:19
Doug, did this just happen or has it been getting worse gradually? Is the oil comming out as oil or blue smoke? As a start, make sure it is firing on both cylinders (replace both spark plugs) then look at the removed ones to see if they are fouled. Make sure the air cleaner cup isn't overfilled. You could have anything from a hole in the piston, bad rings, worn valve guides, plugged oil return from valve cover, bad ventilator pump, plugged air cleaner, overfilled oil sump, wrong weight/diluted oil,or a combination of any of the above, ETC.
