Axle wedge sleeve swap question
Clay
03-24-2001 18:24:10
I have a 5010 with 34's, found a pair of 38's. Here's the dilemma: My axles are 3-5/8" diameter, the other ones are from a tractor with 3-15/16" diameter axles. Question: can I swap the wedge sleeves so that those wheels will fit my axles? The bolt pattern, as near as I can tell, is the same, but that may not mean much.
Thanks for your help. Clay
david val
03-24-2001 20:52:15
 Re: Axle wedge sleeve swap question in reply to Clay, 03-24-2001 18:24:10
if you have a parts catalogs you can see if the wheel # (which are cast on the wheels) crrespond to the sleeve #(usually stamped on the sleeves.
david
jon-deer
03-24-2001 18:37:28
Yes you can, we have 3 5020's and have swapped the wheels with others just by changing the wedges.
