60 rocker arms
mike
11-19-2003 21:18:01
sometimes my rockers start to squeak, mainly when it is up to temp. any ideas on this? thanks in advance
Clooney
11-20-2003 02:36:19
 Re: 60 rocker arms in reply to mike, 11-19-2003 21:18:01
Mike, a few different things can cause that dreaded "rocker arm squeak"..
~The first is not running the engine at a fast enough RPM... If you always idle that engine around it won't properly oil the intake rocker arms as the are only splash oiled.. [always run the engine at rated RPM for a while each time it is started]..
~The second is that you are using an oil additive that makes oil cling [like Lucas].. That stuff will keep the oil from splashing & properly oiling the intake rocker arms.
~The other is that you have a blocked [or broken] oil feed line running to the rocker area.. [if nothing else here fits the problem check the oil lines for blockage]..
~Or you have a plugged, bent, misaligned or otherwise non functioning oiler line above the rocker arms...
~Or the rocker shaft to rocker arm area is so galled it won't allow oil to get between them.. [it might not hurt to pull the rocker cover & inspect the rocker arms to shaft area for galling]...
~If you are using any type of oil additive just drain & replace the oil then run the engine at a high RPM for a while.. Remember those intake rockers are ONLY oiled by oil splash from the exhaust rocker area & the oil mist inside the rocker area...
[email protected]
Bob K - question for Cloo
11-20-2003 12:26:00
 Re: Re: 60 rocker arms in reply to Clooney , 11-20-2003 02:36:19
While I had the rocker arm assembly out of my 50 to dress the valves and seats, I drilled a couple additional tiny holes (smaller than the ones over the exhaust stems) in the oiler tube above the intake rockers. My brother said it may suck a little oil into the cylinders through the guides and smoke a bit, but I figure oil is cheaper than new valves and guides. It puffs a bit throttling up, but runs pretty clean otherwise. It's mostly a show tractor so doesn't get a lot of hard use. Should I have not done this?
Clooney
11-20-2003 13:31:49
 Re: Re: Re: 60 rocker arms in reply to Bob K - question for Cloo, 11-20-2003 12:26:00
Bob, you're not the first to do that.. While that will oil the intake rockers a little more it will allow oil to be sucked in through the intake valve guides & probably eventually coke up the back of the intake valves... It will also take some oil away from the exhaust valves & that is used to not only to oil the exhaust valves it also cools them..
~On a show tractor it probably won't make any difference. Probably won't even hurt a work tractor..
~That way I look at it, those tractors have operated with only direct exhaust oiling for over 50 years without any problems so it probably isn't needed now..
mike
11-20-2003 08:57:48
thanks clooney, I will check it out.
