GAS WHAT FLAVOR
JOHN
03-21-2001 10:58:01
I posted below asking about cold weather starting problems on my 4020. One thing I have been told is that todays fuel quality is not what the old stuff used to be. My question is, what octane of fuel does everyone use. I usually use 89 octane (using the (r+m)/2 method). The tractor seems to run fairly decent on it. If the coop drops off 87 octane instead I can really notice the difference. Does anyone routinely run an octane booster in their fuel ? How about higher octane (aviation gas, racing fuel etc)? Do you blend your own, 1/2 89 + 1/2 120 etc ?
Tom P
03-21-2001 13:05:08
 Re: GAS WHAT FLAVOR in reply to JOHN, 03-21-2001 10:58:01
Don't worry about your fuels octane rating unless your engine is knocking from detonation or pre-ignition. The higher-octane fuel will not start any better or run any better than a lower rated fuel. The Heating Value in Btu/gallon, will effect the power output of your engine. The things to keep in mind when using any fuels with ethanol is its tendency to attract moisture and in some cases may attack rubber components of the fuel system. Because fuels with ethanol contain oxygen, it is also necessary to richen your carburetor to maintain the correct air-fuel ratio.
JD70Jim
03-21-2001 12:04:45
I run a 1967 3020G on 87 octane unleaded. Here in Iowa, 89 octane is ethanol, and while I'm sure it would burn well, it would also probably flush out whatever dirt is in the tank andd clog the filter. There is also 91/92/93 octane premium, but I can't tell any difference except for price, and that's bad enough already.
